Aluminum Base for WE60 Series Sharpeners
This base is made from solid Aluminum. It's designed to keep the Wicked Edge GO - WE60 series sharpeners steady and secure while in use. This aluminum base is finished with black powder-coating, making it easy to clean. It has four rubber feet on the bottom to provide stability, and protect the surface it rests on. The top of the base includes a recessed area to store small parts like the Vise Key and Alignment Guide as well as a dedicated storage slot for the Depth Key.
The sharpener can be mounted to the base via the included screws.
Specs: 8 lbs, 11" x 8.5" x 1"
Compatible with the following sharpener models:
- Wicked Edge GO - WE60
- Wicked Edge WE66 Obsidian
NOT COMPATIBLE with the following sharpener models:
- Wicked Edge GO - WE50
- WE100
- WE120
- WE130
- Generation 3 Pro
- Commercial Series Sharpener
This product is rated 5.0 of 5.0 stars.
It has received 2 reviews.
